by adamjanes Contributor
Is my phone now unlocked?
My 24 month contract finished earlier this month and I was just wondering if this means that my phone is now unlocked and can take any SIM card. Thanks
by Brilliant Contributor
Solution
Re: Is my phone now unlocked?
@adamjanes, have you checked this thread, as it has all the information you need to find out if phone is unlocked:
https://community.ee.co.uk/t5/Unlocking-your-device/Unlocking-your-EE-mobile-phone-or-device/td-p/59...
Solution
Hi @adamjanes
Further to @Schockwave's brilliant answer, the unlocking request form has an in-built status checker that lets you know if the phone needs to be unlocked or not.
Chris 🙂
