Highlighted
New Member
I bought a mini WiFi device in Argos is this unlocked if I wanted to use a diff
Highlighted
by Ace Contributor
Solution
Re: I bought a mini WiFi device in Argos is this unlocked if I wanted to use a d
Hi @Tcm45,
The EE WiFi devices are sold locked to EE. You would need to pay for it to be unlocked.
Thanks,
Peter
Highlighted
by Ace Contributor
Solution
Hi @Tcm45,
Thanks,
Peter
