by StevenN Contributor
How to unlock device
I have a EE mobile WiFi router.
Bought it about 5 years ago.
At one time I am sure I contacted EE to get it unlocked
I can’t remember if I ever received a code or instruction to do this
how can I test the device to see if it is unlocked?
many thanks
8 REPLIES 8
Re: How to unlock device
@StevenN : Test it with a SIM from another network but not 3.
Hi XraySpex
Thanks for your reply
Can I use a phone sim to test the router?
Cheers
Steve
Sent from my iPhone
Yes, as long as it's got some data on it. You could just test it by sending a text.
Thanks again
think I will have to find a suitable sim
the one in my phone is a nano where the device is a big ole standard one.
Cheers
steve
Just get a PAYG SIM from someone like O2. You could even get a free 1 & send a free service text.
Hi XRaySpeX
Just found a sim adapter in my wallet so tried my Plusnet sim.
It connected but it’s Plusnet so as it’s powered by EE only proves it works.
The original sim didn’t connect at all.
Will have to try another sim in later
Cheers Steve
Sent from my iPhone
Unlocking mobile WiFi
I have a mobile WiFi device that I bought years ago
i had requested an unlock code again years ago and was told that it would be unlocked
i haven used the device since
 but now I would like to use it again but on another network
i have tried another sim and get the message Sim Lock so I guess they didn’t unlock it
as I don’t have the time to spend on the phone during the day
is there an email address that I can contact the relevant department to request an unlock code?
many thanks
steve
Re: Unlocking mobile WiFi
@StevenN : Whose SIM did you try it with?
EE provide no email contact.
You can just apply to get it unlocked using the Unlocking your device form and giving the mobile number that it originally came with.
