by Simons1 Investigator
How to unlock LG G5
Hi - I have just received the unlock code from EE for my LG G5 which is now out of contract.
However I can't see where to enter the code. When I insert the other SIM (different network) it just says 'SIM card not recognised' and nowhere to enter the unlock code.
Any ideas?
Re: How to unlock LG G5
@Simons1   Type it in to the phone dialler pad.
Hi @Simons1
Welcome to the community.
Did @Chris_B's advice help? Were you able to type it into the dialler?
The dialler pad isn't visible at that point. Let me have another go and I'll report back.
Just as a follow up....I tried several times and there was nowhere to input the code.
In the end I was advised to do 2945#*850# and the menu came up. Click network unlock, enter code and it worked immediately.
Cheers
Hi @Simons1.
Thanks for the update!
I hope other users can follow your advice if they get a similar problem Smiley Happy
Jon
