by Bobstermama95
New Member
How do i change number with in ee
I have been a customer for many years and now need to change my phone number but don't want to loose anything. Can anyone help?
by Ace Contributor
Solution
Re: How do i change number with in ee
Hi @Bobstermama95
Welcome to the EE Community,
If you call 150 from your EE phone or freephone 0800 956 6000 opt 2 opt 4 from any other phone they will be able to process the change for you it can be subject to a charge of £36 but it is generally free if you are receiving nusiance calls.
Thanks,
David.
by Ace Contributor
Solution
Hi @Bobstermama95
Thanks,
David.
Recent solutions
