by garwen57 Investigator
How do I use my PIN to unlock my phone?
I have requested an unlock code for my Nokia 130. I have had a text from EE giving a 6 digit code but does not say what to do with it. Please can anybody help? Thanks.
Solution
Re: How do I use my PIN to unlock my phone?
We got a long number which had a forward slash in it and could not get this when the sim was taken out. This code didn't come from ee we got it from an unlock code site.
11 REPLIES 11
@garwen57   On the phones dial keypad key in the code you've been sent
Do I keep SIM card in or take it out before entering the 6 digit PIN to unlock my Nokia 130?
Hello Chris. Do I keep SIM card in or take it out and do I need to enter hash tag pw+ etc? Thanks.
by Profile closed
Not applicable
You will need to first insert a different network SIM though to display the unlock entry field.
Once you enter a different none-EE SIM card and then restart the handset, it should then prompt you for the unlock PIN which EE have supplied you with.
by Ace Contributor
You said six digits then this is not unlock code this is a puk code.
by Ace Contributor
You need to request phone unlock code not sim puk code,
Phone unlock code different than puk code and it more than 10 digits
Many Thanks
Solution
by Ace Contributor
OK
Turn your handset on with no SIM card in......
1) Press the # key
2) Press the * key 3 times – this will produce a ‘p’
3) Press the * key 4 times – this will produce a ‘w’
4) Press the * key twice – this will produce a ‘+’
5) Enter in: unlock code that you got
6) Press the * key twice – this will produce a ‘+’
7) Press number 1
😎 Press the # key
9)  “SIM Restriction Off” or “Phone Restriction OFF” should briefly appear on the screen and the handset will re-set itself
Your handset should now be successfully unlocked.
.......but I believe the 6 digit number is not what I want. Is that right? Thanks
by Ace Contributor
As you said it's nokia 130
As I know official unlock code form ee at least 20 digits for this phone.
