by DesiredPunto
How do I get my unlock pin for my phone
Re: How do I get my unlock pin for my phone
@DesiredPunto   If you wish to unlock your device to use on a different network just click the green wording below to see how.  You must select the correct option that applies to you or the unlock will fail.
Are you wanting to unlock your phone to use on other networks or unlock the SIM as you have blocked it by putting in the wrong PIN too many times?
Hi @DesiredPunto
Welcome to the community. 😄
Which code are you looking for? If it's an unlocking code to use a different network's SIM, please follow @Chris_B's advice.
Otherwise, please let us know what kind of code you're looking for?
