by Shelbyjade1
How do I get a unlock for for my old device
Solution
Re: How do I get a unlock for for my old device
If you bought an iPhone directly from EE after 01/09/15 it should have been auto unlocked after 18 months. Using the form below will also confirm this.
If the device had been on your contract for at least 6 months, even if that contract has now been cancelled, you can just apply using the Unlocking your device form aand giving the mobile number that it originally came with. It will first show your new current phone on that number, if any, & ask whether that is the device you want to unlock? If not, you will then have to type in the IMEI of the old phone.
by Brilliant Contributor
Hello @Shelbyjade1 ,
Welcome to the community,
It all depends where you got the phone from etc. I would take a look here as it will give you all the information you need:
https://community.ee.co.uk/t5/Unlocking-your-device/Unlocking-your-EE-mobile-phone-or-device/td-p/76...
@Shelbyjade1 : Did you buy this device yourself new direct from EE or is it 2nd-hand? The process & costs are different.
by Shelbyjade1
I brought the device from EE
Get Outlook for iOS
Solution
