Highlighted
New Member
How can I use my old phone as pay as u go
Highlighted
by Ace Contributor
Solution
Re: How can I use my old phone as pay as u go
Hi @Meriem2011
as long as your old device was with EE or is unlocked you simply need to pick up a PAYG SIM card and pop it in then top up.
Highlighted
by Ace Contributor
Solution
Hi @Meriem2011
