Highlighted
New Member
Does a factory reset re lock phone?
Does a factory reset relock phone? I have had my device unlocked (via EE support) and now done a factory will this have caused the device to be locked again? N.B. I don't have a SIM from another provide to test with.
Highlighted
by Brilliant Contributor
Solution
Re: Does a factory reset re lock phone?
No this will not cause the phone to re-lock
BrendonH (Android Expert) Samsung Galaxy S10+ (Android 10/One UI 2.1)
Highlighted
Solution
