by Ashley1997
New Member
Could I get my phone unlocked when my contact ends
Solution
Re: Could I get my phone unlocked when my contact ends
@Ashley1997 : Yes, if it's not already unlocked. If you bought an iPhone directly from EE after 01/09/15 it should have been auto unlocked after 18 months. Text UNLOCK to 150 to check.
Where did you get this device? Did you buy it yourself new direct from EE or is it 2nd-hand? The unlocking process & costs are different. Is it on contract or PAYG? How old is it?
Solution
by Brilliant Contributor
@Ashley1997 , You contract does not just end, it is the minimum term that ends, when you can then decide to upgrade or you can then go for a sim only contract, if you do not want a new phone, so that the costs are less.
