by Benny2403 Investigator
Can I get my 4gee box unlocked
Hi was just wondering if it's possible to get these 4gee boxes unlocked as I hate the fact I can't see what data I have left, and really if you can't get a simple app like the My EE sorted then personally I don't want to be with your network but I've paid for the router
11 REPLIES 11
Re: Can I get my 4gee box unlocked
How does the device being locked prevent you seeing what data you have left? You can see that from the router's admin interface.
I can't set anything up when I try register it keeps saying confirm number so I do then just tells me to log in which it then puts me bk telling me to register my number and it keeps going round and round, and I wanna know if I can unlock to swap service provider!!!
Sent from my iPhone
by Profile closed
Not applicable
All you need to do to check your data usage with EE is browse to
http://add-on.ee.co.uk/status
Hello there @Benny2403
Thanks for coming here,
Which device are you using?
Does the link provided above work for you?
Thanks 🙂
I couldn't say yet as I'm at work and the box is out in car so will update around half 4/5pm
Sent from my iPhone
Hi @Benny2403
Let us know how it goes 🙂
Yes, MyEE doesn't work for registering MBB devices. It stops at telling you to connect your device & login to it, but when you've done as instructed it doesn't have anywhere for you to say you've done it.
This is supposed to be investigated since I reported it months ago but as far as I know, & you just confirmed it, nowt's been done.
You don't need to register your MBB device in order to use it.
Hi @XRaySpeX
This is being looked into and we will let you know when we get further updates.
Thanks 🙂
Sorry took so long but yeah link worked fine
Sent from my iPhone
Thanks that's a massive help 😌
Sent from my iPhone
Great thanks for letting us know @Benny2403 🙂
