by Kedge
Can I get an LG V20 which is locked to Verizon unlocked to use with EE?!
I've bought an LG V20 which was stated as unlocked. Turns out it's not and is locked to Verizon, an American server! Seller not got back to me yet. Will I be able to get it unlocked to use with my EE sim?
Solution
Re: Can I get an LG V20 which is locked to Verizon unlocked to use with EE?!
@Kedge  If you can get it unlocked it should work with the EE network.  You’ll need the seller to contact Verizon or you’ll need to do this yourself.
Solution
by Kedge
Thanks for response Chris.
