by Chrisburns
Ask need a sim unlocking code for Alcatel 10 16
I need a sim unlocking code for Alcatel 10 16 imei number is xxxxxxxxxxxxx and mobile number is xxxxxxxxxxxx
[Mod edit: Please do not share personal details as your posts are visible to the public. Thanks!]
Re: Ask need a sim unlocking code for Alcatel 10 16
Do you mean to unlock the handset for use on any network?
Did you buy this device yourself new direct from EE or is it 2nd-hand? The process & costs are different.
by Chrisburns
Yes from ee  and new not second hand just don't have 25 p credit to phone up as I'm pay and go and yes its for a new network
by Chrisburns
Yes thank you for you're help I needed the free number I've just seen it many thanks
You can just apply using the Unlocking your device form as the PAYG option and giving the mobile number that it used to have. It will first show your current phone on that number & ask whether that is the device you want to unlock? If not, you will then have to type in the IMEI of the old phone.
EE Employee
Hi and welcome to the community @Chrisburns.
Please see the advice given above by @XRaySpeX as this should help.
Many thanks,
Lee
