by velvetjess1
4G PAYG data sim PUK code
I've recently purchased a Huawei Mobile WiFi E5573C with an EE 4G PAYG data SIM. Initially everything set up and installed without issue. While was setting up the pin code the sim got blocked. I can't find how to get the PUK code to unblock it as it isn't an actual phone. Any ideas? Please help.
Solution
Re: 4G PAYG data sim PUK code
The device may not be an actual phone but the SIM in it has its own actual phone number. Are you aware of it? It would have been on the SIM's packaging when you received it. You should also be able to see it in the router's admin pages as its MSISDN.
Once you have the number set up a MyEE for it. The PUK can then be found under Manage Device. You may have to put the SIM in a real phone to apply it as the router can't dial. Or maybe it can as you managed to set up a PIN. How on earth did you do that?
Solution
by velvetjess1
Hi thanks,
once I put the SIM in a different device I was able to type in the PUK and unlock it.
Just looked at my Router's SIM's original packaging. The PUK & PIN are also on it.
