by killick78 Investigator
retrieving messages
I have a voicemail message but can't retrieve it because of poor signal. Can I use a landline to retrieve it?
Solution
Re: retrieving messages
Hi @killick78
Welcome to the community.
If you've set up a voicemail PIN previously, you can call 07953 222 222 from another phone. It'll ask you to type in your mobile number, then voicemail PIN to listen to them.
Find out more about EE Voicemail >
Solution
Hi @killick78
Many thanks for your help. Had to set up a PIN first but EE texted this to me although they initially thought it had to be done on my mobile.
Thanks again.
One of your colleagues beat you to it and gave a similar answer but thanks anyway.
