by pawelslomka Investigator
issue with text messages
Hi
I have been having an issue with text messages I have been sending not being recieved.
I checked sms centre number and it's correct.
It's Huawei p9 lite and I have done  wipe cache partition as well and nothing change.
Can you help me with it?
16 REPLIES 16
by Ace Contributor
Re: issue with text messages
Hello @pawelslomka delete the text conversation of the person affected then try again starting fresh. It helps if you can get the recipient to do the same on their device.
EE Employee
Hi and welcome to the community @pawelslomka
Has the help from @tm90 above helped at all?
Many thanks,
Lee
Hi
All clear and still the same.
Maybe something get wrong when I swap my old number to EE?
EE Employee
Hi @pawelslomka
Can I gain some more information to assist?
Do your texts get sent and the recipient does not receive them or are you not receiving text messages?
Many thanks,
Lee
Hi
Yes, my texts get sent and the recipient does not receive them.
But when someone texting to me sometimes I don't getting them all.
EE Employee
Hi @pawelslomka
Are these texts UK based or being sent abroad?
Many thanks,
Lee
Yes UK only
EE Employee
Hi @pawelslomka
Did you use a different phone before your number change?
Many thanks,
Lee
No, all the time the same phone.
EE Employee
Hi @pawelslomka
It sounds like our technical team may need to take a look at your account to make sure everything went ok with your number transfer.
Many thanks,
Lee
So probably I will need to ring them or visit nearest store to get it sorted?
EE Employee
Hi @pawelslomka
You would need to give us a call. 🙂
Many thanks,
Lee
Ok
Thank you for your time.
Will let you now when that's fixed.
EE Employee
Hi
the solution of this situation is order the replacment of sim card.
Greetings
Hello there @pawelslomka
Thanks for coming back and letting us know a new SIM card solved this for you.
Come back to the community anytime 🙂
