by AmaanAkh Contributor
iPhone not Sending SMS Texts
Hello EE Community! I Recently bought a new EE Sim and transferred my giffgaff number, ever since I am unable to send SMS Texts, I can receive them, call and iMessage perfectly fine but have never been able to send a text.
I Am using a iPhone 6 iOS 12.2
I Have tried accessing SMSC (message centre) by dialing *#5005*7672# but a "please wait" grey screen comes up for a split second and disappears!, I have tried turning airplane mode on/off and also have tried turning SMS on/off along with iMessage but nothing works! and signal is fine when calling etc.
Solution
Re: iPhone not Sending SMS Texts
Hi @AmaanAkh
Thanks for coming back to me.
I have sent you a private message to get some details.
Leanne 🙂
14 REPLIES 14
by Profile closed
Not applicable
Silly question but have yo tried turning your iPhone off completely and then back on again as that often helps?
Failing that try a network reset but going to Settings>General>Reset>Reset Network Settings and then follow the prompts.
For sending texts, check your phone has the Message Centre no. for EE as +447958879879.
by Profile closed
Not applicable
You cannot change or even access the SMS message centre number setting on any iPhone.
Have tried those steps
how can I change/check my message centre number when I try to dial the code in the dialpad I get a grey screen with the message "please wait" and It disappears.
You can bud it just won't work on my phone.
@AmaanAkh   With EE you can not access the message centre number and with you saying you can your device is still setup for GiffGaff, you need to go to settings>General>Profile and delete any profiles that are there.  Once deleted you need to restart the device.
no profiles, I called apple see if they could help, A supervisor tried helping in everyway possible and his conclusion was it was a faulty sim/contact the carrier. when I try to call 150 It's funny how they ask "to call customer service you need a balance of 0.25p" when I have a £10 pack that starts in 3 days yet I can't text to 150 to start my pack early since my texts don't send.
Try calling customer Services on +44 800 956 6000 (option 2, option 4) . It might not charge.
@AmaanAkh   When did you put this sim in ? Have you tried restarting the device?
Morning @AmaanAkh
Do you get an error message when you try and send a text message?
Leanne 🙂
It will say “not delivered” tap to retry called apple he checked everything and said it’s definitely something with the sim/carrier i do have unlimited texts and have tried everything!
Solution
Hi @AmaanAkh
Leanne 🙂
tried restarting, and I put the sim in 2 months ago and used my PAC Code from giffgaff to keep my number
