by Ant5
Why does my s10+ say mms not supported on network
Re: Why does my s10+ say mms not supported on network
Hi @Ant5
Is this when you try and send a picture message or receive a message?
Do you have your data switched on?
Speak soon 🙂
by Skilled Contributor
Skilled Contributor
For most phones, you can download the MMS settings needed from the online set up tool .
by Ant5
Hi it's when I try and send a picture message and yes data is on
Hi @Ant5
Could you try following the step-by-step instructions on the Samsung Galaxy S10+ virtual device?
Let me know if that helps.
Chris 🙂
Recent solutions
