by DavidSC Investigator
Voicemail
When I press 1 on my mobile to access voicemail, it goes to the old Orange number.  How can I change this to the new EE voicemail number? (I have an ancient Nokia 3310)
Solution
Re: Voicemail
Hi @DavidSC,
You should be able to update the voicemail number in your settings by going to Messages > Voicemail settings.
Hope this helps.
7 REPLIES 7
Re: Voicemail
Hi @DavidSC.
Welcome to the EE Community 🙂
Could you try dialling 222 on your phone and see if you're able to access your voicemail?
Let me know if this works 🙂
Jon
Re: Voicemail
Hi Jon,
Thanks for your reply.
Yes, 222 works fine - it's just that the shortcut key is set to 123,
which is now a speaking clock.  How do I reset that to 222?
David
Solution
Re: Voicemail
Hi @DavidSC,
Hope this helps.
Re: Voicemail
Thanks James - that solution works fine.
Thanks for your help,
David
Re: Voicemail
That's great.
Thanks for letting me know @DavidSC 🙂
by kheushna
New Member
Re: Voicemail
Hi
Re: Voicemail
Hi @kheushna,
Welcome to the Community. 🙂
How can we help today?
Recent solutions
