by gazchad Contributor
Voicemail on Flex
I've recently moved from monthly to flex, and have lost access to voicemail.  I've tried the texting VM On and off to 150, and that didn't work, so i did a live chat on techincal support and they said pay as you go don't get voicemail.
I've just looked on these forums and it's looking like it's just VISUAL voicemail that's not supported... Is my account broken, or do we not get voicemail at all?  I'm so confused!
Solution
Re: Voicemail on Flex
SOLVED 🙂
Apparently I had something set up wrong on my account.  They fiddled with a few settings on their end, and fixed it for me 🙂   Live chat person was wrong 🙂
6 REPLIES 6
PAYG incl. Flex should be able to use VM. I've just tried it & get the response "Your request to turn on conditional diverts has been successful".
Have you tried texting VM OFF to 150 followed by VM ON?
Hi @gazchad
EE voicemail guide is here:
https://ee.co.uk/help/help-new/getting-started-and-upgrading/using-your-phone-features/how-do-i-use-...
Yeah. I tried off and on again like i've seen mentioned on these forums, and they both come up with the same error 😞
Hello @gazchad
I would like to help you get your voicemail looked into, you will have a private message from me, so I can get some details from you 🙂
Solution
SOLVED 🙂
Thanks for getting back to us and letting us know, @gazchad 🙂
