02-08-2018 04:51 PM
Hi All,
I have already searched the existing posts and see this is a re-occuring issue.
VM OFF, VMOFF and VOICEMAIL DIVERT OFF to 150 both return the message "We've had a problem with your request, please try again a little later"
Any solutions to ensure my voicemail is turned off and I'm not charged for this?
Thanks!
02-08-2018 06:55 PM
02-08-2018 06:58 PM - edited 02-08-2018 06:59 PM
@vvv1979 Have you tried calling the 150 automated system?
There is an option when you call 150 to turn on or off your voicemail from the automated menus.
Option 1 for mobile phones, option 3 for tech support (voicemail option are in this menu but not mentioned), option 3 for voicemail then follow the instructions.
03-08-2018 08:13 AM
04-09-2018 06:31 PM
Hi
I have same issues on my pay as you go
Tried numerous times to switch off the voicemail. Tried VM off and voicemail divert off before leaving UK
Also my phone settings for call forwarding is off
It gave me successful messages that it's done
Numerous times I called my phone and it wasn't working
Then all of a sudden it started working
Now that I am abroad, voicemail is back on again
Tried VM off etc and it give network error
Call forwarding is all off too but still if someone rings it goes straight to answering machine
Tried ee customer service and all they did was reset my phone network settings and asked me try again but same no result
Phone just goes directly to answering machine ... Won't even ring
This is extremely annoying
Using oneplus5t if it helps
Regards Atif
05-09-2018 08:31 AM
Hi @Atifmalik78,
Welcome to the EE Community.
I'm sorry to hear you are having problems turning off your voicemail.
Please get in touch with customer services so we can take another look at your account.
30-03-2022 10:56 AM
Hello,
I am having the same issue.
I need to turn voicemail off but for days now have only had this reply;
"Sorry, we're having some trouble completing your request at the moment. Please try again later."
I have texted 150 with;
"VM OFF"
"VOICEMAIL DIVERT OFF"
" VM ON" - "VM OFF"
I have spoken with EE and they have reset my SIM and this has also not corrected the issue.
Very frustrating.
Please post the solution here ASAP.
Thank you.
30-03-2022 11:06 AM
Hi @chrisc990,
If you are unable to deactivate your voicemail service by texting VM DIVERT OFF to 150, please get in touch with Customer Care so our Technical Support Team can help.
