Highlighted
by Investigator
Suspect tesxt message re PAC code
I got a text, purporting to be from EE, saying my contract will be suspended if I don´t update my PAC code. I suspect the text may be fake, since nothing has happened for a few days. I need my phone for my work and am anxious it will suddenly cut out. I´ve tried ringing EE, but - for obvious reasons in the current climate - the wait is impossibly long. Please help.
Highlighted
by Ace Contributor
Solution
Re: Suspect tesxt message re PAC code
Hi @smahier
Welcome to the EE Community,
It's fake EE wouldn't text you asking for a PAC code as they are the ones that would provide it to the customer.
Thanks,
David.
6 REPLIES 6
Highlighted
by Ace Contributor
Solution
Hi @smahier
Thanks,
David.
Highlighted
by Investigator
Thanks, David. My only worry is I clicked on it, since at first it did seem legit. Should I just delete it?
Highlighted
by Ace Contributor
@smahier forward the text to 7726 so EE can investigate it 🙂
Highlighted
by Investigator
OK, thanks.
Highlighted
by Ace Contributor
@smahier your welcome if you need any further help visit us here on the community 🙂
Highlighted
Are you in the process of requesting or using a PAC?
Recent solutions
