by AndrewLowe Investigator
Sending a text message
Having tried to send a text message my phone has got stuck on the screen saying 'sending message'. I have pressed every button but it just stays stuck! Can you help please.
Solution
Re: Sending a text message
Eventually the phone ran out of charge. By recharging the fault was cleared. All sorted any many thanks for your help.  Andy
8 REPLIES 8
by Ace Contributor
HI @AndrewLowe What phone have you got? Have you tried holding the power button in for a while?
Thanks for the reply. Just tried it but no reaction. The phone is a Sony Erikson C905. There is no screen at all now. It had gone blank before your fix advice. Andy
by Ace Contributor
It has a removable battery doesn't it? Have you tried taking it out and putting it back in again?
Phone is now on charge.  The phone was well charged beforehand but I guess the screen being on all the time has drained the battery. The phone is taking a charge so lets hope this will reset it.
@AndrewLowe: Check that the message centre no. for EE is +447958879879.
Solution
by Naomi31
i have unlimited texts and ive put my sim into a htc mini plus and it will not send any text messages do you have any ideas on how i can fix this please ?
Hi @Naomi31,
Have you checked that you have the correct message centre number in your settings?
It should be +447958879879.
Recent solutions
