by zakald_ Investigator
SMS Centre Number does not update
I recently came back to this country. I purchased a new EE Sim Card (Pay As You Go) a few weeks ago. However, since then, I cannot send texts. I do receive them though. I can also call and receive calls.
I made a lot of trips to a EE store and made calls to the helpline. Overall, I spent a lot of time to solve this issue that is still ongoing. I know the problem comes from the SMS Centre Number. Each time I am updating it, it has no effect, and my texts are not sent. I tried everything: putting +44 before the number, "+44XXXXX", 145, etc. I still cannot send texts.
When I go back to check on my SMS Centre number, there is always a blank space. However, when I click on "refresh", the one I just put reappears.
When I use the "+44XXXXX", 145 version, I receive the message "update-error".
I have a Nokia 3 (Android). I have 2 Sim Cards on my phone: the EE one and a French one. I tried to only use the EE Sim Card, but the situation was even more catastrophic since I could not update at all.
I need to mention that I already had another EE Sim Card with this phone, and it worked perfectly well!
Please, help me!
8 REPLIES 8
Re: SMS Centre Number does not update
Hi @zakald_
Welcome to the community.
Are you able to try putting your SIM card in another phone and sending a text?
Have you tried factory resetting your phone?
Jon
Hi @Jon_K ,
Thank you so much for your help.
I did try to put the Sim card on another phone, and I managed to send a text.
I did not try to factory reset my phone because I believe this would delete all of my data - which is something I would very much like to avoid.
Zak
Thanks @zakald_
It sounds in this case like the issue is following the phone.
Could you try backing up your data first before a reset?
Is your phone on the latest software version?
Jon
@Jon_K ,
I just backed up my data - will this enable me to recover it after a factory reset?
Yes, my phone is the latest software version: Android 9.
So, do you think I should reset my phone to solve this issue?
Thank you again.
Zak
Thanks @zakald_
Where did you back up your data?
This will be the best current option to get it working again.
Jon
@Jon_K,
I backed up my data using Google Drive, which is the option proposed under Settings
Zak
That's great, @zakald_ 🙂
You will be able to recover your data once you've reset the phone.
Let us know how you get on with this.
Jon
Hi @Jon_K ,
I reset my phone and recovered my data.
It was a long process, but I can finally send texts.
Thank you so much for your help!
Enjoy the rest of your day!
Zak
Recent solutions
