by Jared78
Print texts
I need to print my texts for court they need to show time and date. How do I do this. I have all texts on my iPhone SE
by Ace Contributor
Re: Print texts
Easiest way is to take screenshots of the texts that you need to print off.
To take a screenshot, do the following:
Press the Top button and the Home button at the same time. Quickly release both buttons after doing this.
After you take the screenshot, a small thumbnail temporarily appears in the lower left corner of your screen. From there you can tap the thumbnail to open it or swipe left to dismiss it.
The screenshots will then be stored in the Photos app on your iPhone. From there (depending on if you have a wireless printer) you can print them off.
by Jared78
Re: Print texts
Many thanks, there are three years of texts is there a way to print to file ?
by Ace Contributor
Re: Print texts
It would probably involve you needing to purchase a third party piece of software for your computer. But I'm unsure as to if this would show all the dates and times you would be wanting.
by Jared78
Re: Print texts
Thanks for that I will have a look online
Recent solutions
