by mrsshocks Investigator
Is a text from AWS a scam?
I recieved this text from AWS - no number -
 , someone made a log-in attempt from 7.4.5.35. If you did not do this, use 099835 to confirm your identity http://amn.red/12pslee
I have no idea what this is for. Is it a scam? How do I stop it happening again? Thanks.
by Profile closed
Not applicable
Re: Is a text from AWS a scam?
Hi, @mrsshocks,
Sound's like a scam so just ignore it!
If it happen's again then forward the message to 7726
mAh8v
by Ace Contributor
If in any doubt just ignore and delete.
BrendonH (Android Expert) - Samsung Galaxy S8+ (Pie 9.0 Beta)
If I have helped you please click on the STAR/SOLUTION buttons below
by Profile closed
Not applicable
Hi, @BrendonH,
Thanks for your help! 😊
mAh8v
by Ace Contributor
A quick google search shows that it is from Amazon Web Services. Are you signed up to that?
If so log in manually and just change your password
Thank you.
by Profile closed
Not applicable
Hi @mrsshocks,
You're welcome 😊👍
mAh8v
Thanks. I found this on Google too but was still a little unsure of the link they had sent. I changed my Amazon account password right away as a precaution. I still think it is a scam text though.
by Profile closed
Not applicable
Hi, @mrsshocks,
Following on from my and @BrendonH, advice, you did exactly the right thing! 😊👍
I like BrendonH both checked the message to be sure!
If you get anything else like this, just remember to google it first! 😊👍
mAh8v
