by Markjl91 Investigator
I can receive texts but can't seem to send them?
Since I installed the new Samsung one ui, I'm unable to text people but. I have receive texts with no issue.
Solution
Re: I can receive texts but can't seem to send them?
I've discovered the solution. It seems to be Spotify that's the culprit. It's a Samsung issue with the new android update. Go to settings > apps > Spotify > force stop. Problem solved!
For sending texts, check your phone has the Message Centre no. for EE as +447958879879.
Good Morning @Markjl91.
Let us know if the Message Centre number fixes this for you, if not we can certainly try to assist you further 🙂
Jon
Hi so I've changed the message centre number to +447958879879 but my messeges still aren't sending. I've downloaded a new messaging app from the play store and that's working fine . With that said,  I'd much rather use the stock messaging app. Any ideas of what u think the issue is would be great .
Solution
Hi @Markjl91,
I'm glad you managed to get this resolved!
Thank you for posting your findings here on the community to help others with the same issue 🙂
Hope to see you back soon.
Alex 🙂
