Highlighted
by Investigator
Hi
Hi! I Have a problem with receiving text messages since I transfered my old number
Highlighted
Solution
Re: Hi
That could explain it, @sylwia2020.
It seems people are still iMessaging you and those are the ones going through to your old phone.
If you turn off your iMessage on your old phone, it should stop this from happening:
Tap Settings > Messages > Turn off iMessage.
Let me know if that works.
8 REPLIES 8
Highlighted
Re: Hi
@sylwia2020   Have you restarted the device since the port ?
Highlighted
Re: Hi
Hi @sylwia2020
Did you use a PAC code to transfer your number over? If so, when did you give it to us?
Which network did you transfer from?
Highlighted
by Investigator
Re: Hi
I received a pac code from three network and I was chatting with an advisor last Sunday. She did everything I can use mobile data making a calls and answering calls but I cant receiving text messges. They coming to my old phone I need to sort it.
Highlighted
Re: Hi
OK thanks @sylwia2020. It should have ported fully on Tuesday then.
What kind of phone are you using now? And what kind of phone were you using before the transfer?
Highlighted
by Investigator
Re: Hi
Now I am using huaweii p30 pro and I was using iphone 8 before
Highlighted
Solution
Re: Hi
Highlighted
by Investigator
Re: Hi
Yes now it works. Thank you for your help
Highlighted
Re: Hi
Ah that's great, @sylwia2020
Glad it's all working now. 🙂
Recent solutions
