by Leah5 Contributor
Contacts
Hello if someone has sent me a text without being in my contacts  (or just their number shows in messages). How do I add them to contacts from the text messages?
Solution
Re: Contacts
Thanks for confirming this @Leah5
If you go into the conversation you should receive a pop up giving you the option to 'Add contact' or 'Report spam'. If this does not show you can manually add this by selecting the three dots in the top right corner.
Katie 🙂
Re: Contacts
@Leah5   Helps to say what device it is.  But you can usually just open the text and click the number that it’s from to add it as a contact.
Re: Contacts
It's Huawei p20lite
Solution
Re: Contacts
Katie 🙂
Re: Contacts
That's great thank you!
