by SD47
Change my password for mms login screen
I've just used my mms login for the first time. How do I change the password to one I'll remember. Any help very much appreciated. Thank you.
Solution
Re: Change my password for mms login screen
@SD47 : Are you talking about the pwd to get a received MMS from https://ee.mms.ee.co.uk/eeuk/ ?
You don't need to remember this pwd. A new 1 is texted to you each time.
Solution
by SD47
Thank you for your response. Very much appreciated. Very helpful thank you
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
Hi there @SD47
Welcome to the community.
What phone are you using?
You can download the settings for picture messaging from our online set up tool, this will bring the picture to your phone so you don't need a username and password each time 🙂
Thanks 🙂
