by Behenjamin
Cant receive uber verification code
I can't receive a verification code from uber to verify my account. It says to text a number 'start' in order to receive it. But it blocks me from sending these too.
Re: Cant receive uber verification code
Have you recently ported in from O2?
by Behenjamin
Around 2 and a half years ago i had this number on o2.
by Skilled Contributor
Skilled Contributor
If you're also unable to send text to shortcode numbers there may be a restriction on your account. Have you asked customer services to bar premium/competition type text?
by Ace Contributor
Are you roaming at the moment and putting the number in, in the correct format?
Hi @Behenjamin,
That number doesn't look to be in the correct format.
It should either start with +44 or 0, not +0.
Hope that helps.
Recent solutions
