by AmyWrites Investigator
Can't receive texts since transferring old number to EE
I was with a provider that recently went out of business, so I took my PUK into my local EE store and switched my old number over to a Pay As You Go SIM. Since then, I can't receive text messages - I can receive and make calls, and I can send texts fine, but it's just the receiving texts that's not working for me. I'm just wondering how to resolve this.
Thanks in advance!
6 REPLIES 6
by Ace Contributor
Re: Can't receive texts since transferring old number to EE
Hi @AmyWrites
Welcome to the EE Community,
Can you get texts from anyone or is it certain types of texts like from banks ?
Hi David_C,
It's all texts as far as I can tell - stuff from friends in the UK and abroad, login verification texts from websites, etc.
by Ace Contributor
@AmyWrites is your old sim disconnected ?
Have you spoken to EE technical support ?
This is interesting... I just put my old SIM back in it gave me a message letting me know it wasn't connected, but then all of the texts I've been expecting came through. So I have no idea what that's all about. Thanks for putting it in my head to check - I just assumed the SIM would be junk after the switch.
I haven't spoken to technical support - I came on here looking for a way to contact them and found the community instead. What's the best way to get in touch with them, please?
Hi @AmyWrites,
When did you transfer your number?
What type of phone are you using?
by Ace Contributor
Hi @AmyWrites best way to get through to tech is freephone 0800 956 3146.
