by energyflash Investigator
Can't receive Santander OTP code on iPhone please help!
6 REPLIES 6
Re: Can't receive Santander OTP code on iPhone please help!
Hi @energyflash
Have you just migrated over?
Try turning off iMessage.
hey @Northerner thanks for your reply! I have turned off imessage but still not receiving the OTP, also I moved my number over from giffgaff today and its gone over fine (can receive calls to my EE sim on my old number that the OTP is registered to) but I still can't receive the text
marked as a solution in error, this is certainly not resolved unfortunately
@energyflash
Your number hasn't ported over fully hence why you cannot receive the code. If you check under settings, is your temporary number still showing?
If you search these forums you will see this issue is common.
by Holljc Investigator
Hi. Did you ever get a solution to this? I'm having the same problem and I've been told by the network they can't help.
Hi @Holljc,
Welcome to the EE Community.
Please get in touch with Customer Care so our Tech Gurus can get this sorted for you.
