by SONICYOUTH Contributor
Can receive but not send text messages
Re: Can receive but not send text messages
Good Afternoon @SONICYOUTH
Welcome to the community.
Are you with us on pay as you go or pay monthly?
Can you make calls?
Also, what phone are you using?
Leanne Smiley Happy
For sending texts, check the message centre no. for EE is +447958879879.
To phone EE: The local rate landline number 0207 362 0200 or Freephone 0800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & EE TV.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC = 2014: EE 20 Meg WBC
I can make and receive calls just says failed when I text. I am on PAY As you GO with an HONOR 9 lite Phone. I am also in Portugal like another customer.
Yes, check your message centre no.
Message center number is correct. Also won't let me send texts with my Portuguese Sim number. Same problem - failed to send.
Search Mobile Operators & try switching to your Portuguese network.
With my EE Sim phone has switched to ALTICE MEO and Portuguese Sim is NOS. Neither will let me send texts but am receiving on both.
Morning @SONICYOUTH
Thanks for coming back to us.
Is this to one number that you cannot text?
Are you using both SIM cards in the same phone or different?
Speak soon, Leanne Smiley Happy
Hi Leanne
I have tried various numbers both to UK and in Portugal using both sims and all fail. The phone is dual sim and I can flip between each sim when I want to call. Calls using either sim are working
Thanks @SONICYOUTH
Have you been able to send texts previously?
Can you text AL to 150 from your EE SIM, does this work?
Yes that seems to work
Hi @SONICYOUTH
Thanks for trying.
How many numbers are affected?
Can you call the numbers?
Thanks, Leanne.
Don't know exactly but every number I have tried to text or return text has failed. As far as I know I have not had any problems calling anyone.
Hi @SONICYOUTH
Do you have the correct dialling code set for the contact?
Can you try and call one of the numbers to see if this works for you?
Leanne Smiley Happy
What exactly does texting AL to 150 from your EE SIM tell you?
