by Hopalong Investigator
7726
hi,
I was advised to forward a phishing text to 7726 - but it would not go . it just stayed on my screen with an exclamation mark?  as do texts when I try to stop the information texts?
Any idea why?
Hopalong.
PS the phishing one has really knocked my confidence!
Solution
Re: 7726
Good Morning @Hopalong
Are you able to send normal texts successfully?
What phone are you using?
What are these texts advising?
Katie 🙂
Solution
Re: 7726
Katie 🙂
Re: 7726
Thanks Katie
I have a sony smart phone - all other texts 'go'   but the one I wanted to forward to 7726 just wouldn't go ...so I was unable to 'forward my scam text' as advised.
The only other text reply that will not go - and shows the exclamation mark, is one to EE  when I try to stop them sending me promotional texts by using their suggested 1234 number to stop these?
any help welcome...
Hopalong
Re: 7726
How unusual, @Hopalong.
You should be able to send messages to both numbers. I recommend speaking to our Tech Gurus, they'll be able to run through some troubleshooting with you to get to the bottom of the problem.
