by NigelIanson Investigator
TVPlayer Plus
I have registered for TVPlayer plus and can see it in the on demand section but attempting to do the same throught the EE TV guide I get No connection to the service. Can Anyone help?
Solution
Re: TVPlayer Plus
Hi @Nigellanson,
Yes you should be able to access this via your EE TV set top box.
You should see the additional channels to play within the 'on demand' section of your EE TV.
The TVPlayer PLUS app is featured on our EE TV deals
Alex 🙂
7 REPLIES 7
Re: TVPlayer Plus
Hi @Nigellanson,
Welcome to the community 🙂
Did you manage to get connected yesterday to the TV player app?
Alex
Re: TVPlayer Plus
I still have the same problem. I can get connected to TVPlayer plus through the TVPlayer app and what programs with no problem. What I cannot do is enter the EE TV guide and select a program on a channel eg History and then whatch a program on that channel even though the details of the program are available. It would appear that there is a problem with the integration of TVPlayer and EE. I have logged out of and in to TVPlayer, switched off and on the EE box and also the internet router, checked the internet connection and speed (EE internet 30mb). What next?
Re: TVPlayer Plus
Hi @Nigellanson,
I would suggest giving our Home Broadband Tech Gurus a call as the next step as you have tried the steps that I would have suggested 🙂
They will be able to give you further information regarding the playback via EE TV.
Let me know how you get on once you have spoken to them.
Alex 🙂
Re: TVPlayer Plus
Thanks Alex
Could you just please confirm that I should be able to access TVPlayer channels through the EE TV guide?
Solution
Re: TVPlayer Plus
Hi @Nigellanson,
Alex 🙂
Re: TVPlayer Plus
The solution to this problem was resolved by the broadband tech team by instigating a complete reset of I presume the EE TV box. This is in advanced settings and and once back up all the programs were available on my TV guide.
Re: TVPlayer Plus
Great  @NigelIanson
Thanks for coming back and letting us know.
Leanne 🙂
