by Kris23
TV signal
Why do the pictures and sound break up? This is happening on all channels despite the signal strength being 82%.
When I disconnected the ariel lead from the EE box and plug it into my television,  the signal is fine. Also another television which is in a different room and not connected to EE TV picks up Freeview channels with no issues.
Re: TV signal
Hi @Kris23
Have you tried rescanning for the TV channels?
Have you tried a box rest?
by Brilliant Contributor
Re: TV signal
@Kris23, have you made sure that you have a cable going between the TV and your EETV box?  Have you checked how to set it up correctly for it to work?
by Kris23
Re: TV signal
Yes the box is connected to the TV is was working until last night. This is
the second box.
Re: TV signal
@Kris23, I would advise you to speak to the technical team at customer service, as the box may have developed a fault and may need replacing once again, unless they can come up with a solution if it had been previously working.
Re: TV signal
Hi @Kris23
Welcome to the community.  🙂
I recommend following @Schockwave's advice and speak to our Broadband Gurus.
