by Expert Contributor
Expert Contributor
EE TV Cheat
Here is a cheat for the EE TV that I have come across. It maybe even an undocumented feature rather than a cheat, but here goes...
If you have missed a program on a channel which is not included in your REPLAY settings, you can go into the settings - select the channel that the program you missed is on (provided it is one of the options!) - move the required program from REPLAY to RECORDINGS - reset your REPLAY settings back to what they were previously.
Works a treat.  I use it for BBC Alba which I do not have as REPLAY option but I do like some of there programs occasionally which I tend to miss.  Handy little cheat/feature.
Re: EE TV Cheat
Hi @kmmc55,
Thank you for sharing the handy hint you have found 🙂
Alex
