by Tinababeena Investigator
Nest installation
PLEASE CAN SOMEONE HELP ME
so I’ve got a nest sitting here in a box on my coffee table waiting to be installed. I tried the website in the installation instructions, but it doesn’t accept my postcode or address, it just says “ postcode is invalid”
I called three customer service numbers, the last one being the  EE smart home helpline, only to be told “yes we know about this issue. Wait 48 hours to see if it’s fixed”
so ive waited three days and it’s still not working.
EE recommend that you book your installation within 14 days of purchase, but I can’t because of a website glitch.
anyone got any suggestions??? Has anyone else had this problem??
15 REPLIES 15
Re: Nest installation
What website in the instructions? Nest's? Isn't this a Nest issue, not EE's?
Hi @Tinababeena
This site https://axainstallmydevice.com/EE/
Yes it doesn't work in chrome on my Tab S2 or Galaxy S8+ although I'm not sure it's your postcode or some other code you enter?
There is a number to call (click on the three lines) 07953 960 250. No idea who that connects with.
Hi @Tinababeena,
Welcome to the EE Community.
I'm sorry to hear you are having problems booking your installation.
Have you contacted the Smart Home Team to let them know the problem wasn't rectified after 48 hours?
Hi there!
yes I’ve called that number and that’s who have told me to wait 48 hours.
The first two numbers I called were the one on the axa website.
The smart home help assistant said he knows of the issue as lots of people have called regarding this so to me that sounds like it’s not my postcode or anything I’m entering that’s making it not work. Plus after he said that I did try my mum and my dads postcodes and this also came up with the same error.
Well ive checked again (day 4) and it’s still the same. So will call again to see if they can do anything, although they said there is no other route to book installation.
The website is axa who EE have partnered with to carry out the nest installations. You get a code to enter which is fine, you answer some questions regarding your boiler, and then when I come to input my address I feel the way the website it set up there should be a search button, so when you enter your postcode you should be able to search and select your house number and address but this button is missing.
It's not your postcode but an install code which should have come with the product.
Thanks @Tinababeena
Please let us know how you get on.
by Ace Contributor
The postcode box doesn't have a search button and produces the error.
Yes exactly. This is very frustrating ! We have tried different browsers eg chrome, safari and internet explorer to see if that resolves the issue but no it still produces an error saying my “postcode or address is invalid”
I’ve called the EE smart home help number and told them I’ve waited 48 hours and the website still isn’t working.
they have now told me to wait a further 48 hours. That’s rediculous and I feel like I’m being shrugged off.
Not quite sure what to do !!
Hi @Tinababeena
You have four options:
  1. You can wait;
  2. You can return the device under the 14 day rule;
  3. You can complain;
  4. You can ring them again tomorrow, and every hour until it's sorted.
@James_B is there nothing you can do here?
Hi @Tinababeena,
I'm looking into this for you and I'll get back to you as soon as possible.
by smigg221174
New Member
I'm glad it's not just me!! Whilst I know that it is Axa that are providing this, EE have contracted them as their partner and so EE have an obligation to assist in getting this resolved. Unless of course EE are going to delay taking the additional money that they are charging people on their mobile contracts, but I already know the answer to this!
Hi @Tinababeena and @smigg221174,
I've sent you both a private message.
by Tim563 Investigator
Check Nest compatibility and get a wiring diagram Install your thermostat on the wall - You are here Set up your thermostat Connect your thermostat to the Nest app Get started using the Nest thermostat
Recent solutions
