by James55
Does anyone have problems live streaming from a Hive View camera across the Net?
I have a Hive View camera which has been working fine until the last Hive app upgrade about a week ago. Following the upgrade I can no longer live stream from the camera over the internet. Has anyone else experienced this issue?
Re: Does anyone have problems live streaming from a Hive View camera across the
Good Morning @James55
Does this happen in more than one location?
Have you been in contact with Hive about this?
You could also try talking to the Hive Community Smiley Happy
Jon​​​​​​​
by James55
Hi Jon. I have chatted with Hive and they say there is an issue with EE. They said they would stay in touch re the issue. I have noted on the Hive community that there are others with same problem but I don’t know if they are with EE.
Sent from my iPad
Thanks for the update, @James55
Keep us posted on what happens please.
Does Hive have a Cloud-based method of viewing the camera whereby you login to the Hive site & they show you the images? Or do you have to access the camera directly via the IP of your router & the port of the camera?
To phone EE: The local rate landline number 0207 362 0200 or Freephone 0800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & EE TV.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC = 2014: EE 20 Meg WBC
