by carla69
New Member
will my micro sim card fit in iphone 6
I have a mobiwire pictor (micro sim card) will I be able to use it in an iphone 6
by Profile closed
Not applicable
Re: will my micro sim card fit in iphone 6
No, it won't fit sorry as every iPhone after the 5S now uses the smallest nanoSIM.
You will need to swap your SIM card.  The easiest and quickest way to do this is by calling into your nearest EE store.
