by camshelmerdine
why is my data not activating
I just got a new phone and transferred my old sim into it, but every time I try and use my data it says my data cannot be activated and my phone is not connected to the internet - how do I fix this?
Re: why is my data not activating
Hi @camshelmerdine
  • What phone do you have?
  • Is mobile data active on your device?
  • Are you PAYG or pay monthly contract?
by camshelmerdine
iPhone 6s
It should be active it literally worked the other day
monthly contract
Hi @camshelmerdine
Try resetting your network settings.
Are you in the UK?
Good Afternoon @camshelmerdine
Thanks for coming here.
Is this all apps and websites?
Can you try a network reset as below;
Go to Settings > General > Reset > Reset Network Settings.
This will remove any saved WiFi passwords.
Let us know how you get on 🙂
