by angelak2271 Investigator
my ee samsung galaxy 4s won't recognise my virgin sim
I have a EE samsung galaxy s4...i have tried using my virgin nano sim (using a micro sim.adapter) from my Apple unlocked 5s ..but the ee galaxy s4 phone says no sim emergency call only??
8 REPLIES 8
Re: my ee samsung galaxy 4s won't recognise my virgin sim
Is the phone unlocked?
it's a virgin sim in an ee phone..been told it should work as they use the same  network
by Pete_C1 Valued Contributor
Valued Contributor
Even if they use the same network, the phone may still need to be unlocked.
i would get it unlocked and see if it works then.
its like tesco mobile, it uses O2 network but all the phones have tesco as the provider.
I've just tried an ee pay as you go and it still says emergency calls..ive gone into settings and networks..and it's saying to insert a SIM card
Samsung s4 emergency calls only
my ee samsung galaxy s4 is saying emergency calls only...the original sim I got was deactivated as i upgraded ..i gave the pbone to my neice  now its saying no SIM card..also..when I go.to settings . .more networks..it says insert a SIM card...i have tried a contract virgin sim and a EE payg and  its saying the same
Hi @angelak2271
Welcome to the community.
Is there any dust or any marks on the gold SIM connectors?
The error message indicates that the phone isn't reading the SIM at all.
Also, is it definitely locked into place correctly?
it's definatly in correctly as it clicks in when it's inserted
OK, thanks for confirming, @angelak2271.
I recommend speaking to our technical support team so that they can help you with this.
Please let me know what happens.
