by TGS
New Member
iphone 8 Sim Pin, Guide is not up to date.
How do I activate my Sim on the iPhone 8? the guide on this site is not up to date with the current IOS 13.1.1 So When I press phone button in options there was no Sim Pin option!
Solution
Re: iphone 8 Sim Pin, Guide is not up to date.
@TGS  iOS 13.1.1 is not the current iOS it’s 13.2.3 and to setup a sim pin
  1. go to Settings > Mobile Data > SIM PIN. ( this will not active a sim though as this is a lock you can enable on the sim that needs to be entered every time the device is switched on or if the sim is removed from the device)
If the sim needs to activate this can take up to 24 hours but it’s usually 4-5 hours.
Where did you get this device from ?
Solution
Recent solutions
