by Machiberg Contributor
gave+my+daughter+my+LG+G5+but+her+PAYG+sim+wont+work
hi,
I gave my daughter my old LG G5, shes on Vodafone and had broken her phone.
I have inserted her sim and it says network locked, so I have gotten the handset unlock code from EE however it doesn't ask for this code when I start it up.
if I swap the sim into my Galaxy S8 it does so immediately on start up and the sim still works in her old phone
help im now confused on what to do?!
Solution
Re: gave+my+daughter+my+LG+G5+but+her+PAYG+sim+wont+work
@Machiberg   Please try this
If your phone does not ask for the unlock code and it only says “Network Locked” then, as if making a call, dial: 2945#*model number# or *#865625#. Once prompted for code enter the unlock code and your phone will be unlocked.
Solution
legend Chris_B its got me to the screen and unlocked the handset
shes super happy now so thank you so much!!!!!
Glad you got the help you needed from the community @Machiberg
Have a great weekend.
Leanne 🙂
