by amina83
New Member
do i need id to get a replacement sim in store?
called EE and was told that i can get a replacement sim instore. Do i need ID?
by Profile closed
Not applicable
Solution
Re: do i need id to get a replacement sim in store?
Hello @amina83 you will need the old SIM card or a valid Driving License/Passport photo ID to get a replacement free from store. 🙂
by Profile closed
Not applicable
Solution
