by damienxz26
changing numbers
i have a 10 pound 30 day pay as u go pack can i keep the pack if i change to another ee sim card
by Ace Contributor
Re: changing numbers
Hi @damienxz26
Welcome to the EE Community,
If you speak to customer services on freephone 0800 956 3146 they will be able to change the number on your current SIM if you require a new number.
Thanks,
David.
by damienxz26
i wanna be able to have my current 30 day pack added to a new number
by Ace Contributor
@damienxz26
If you ring 0800 956 3146 they will be able to change your number on your current SIM that way you will keep your current 30 day pack.
Hi @damienxz26
Welcome to the community and happy New Year! 🙂
Our Mobile Care team on 150 will be able to run through your options with you.
Recent solutions
