by Dapper
can I have 2sims with the same number?
I would like two separate mobile phones, but each would need to have the same telephone number.
Solution
Re: can I have 2sims with the same number?
It's not possible to have the same number on two sims with EE.
You maybe able to use a third party redirecting service or number.
Solution
by Ace Contributor
HI, @Dapper
Sorry no it is not possible to have same number in two mobiles.
