by Chaltonadvisor Investigator
When changing phones l did to change tariffs
When l want to change phones do l need to change tariff as different sized sim
10 REPLIES 10
When l want to change phones do l need to change tariff as different sized sim currently orange tariff
Re: When changing phones l did to change tariffs
@Chaltonadvisor   When you upgrade to a new phone you also have a new tariff.    Sometimes you do not get a new Sim card when you take out a new tariff/device as your existing Sim card will fit the new device.  I’m still using the same SIM card I got about 4 years ago.
I don't want a new tariff just swapping phones?
Brilliant answer @Chris_B
I hope this is what you needed @Chaltonadvisor and please do come to community anytime.
Great to have you here.
Richard
Hi @Chaltonadvisor
What kind of phone are you using?
Have you had a look at our Help With Your SIM help and support pages.
Have a quick look please at the types of SIM card information.
Their is some fantastic information there.
Let me know if you need anything else.
Richard
@Chaltonadvisor   you can put any Sim card into any phone and if you need a new Sim card for that new phone  because it’s a different size then you just called customer services and they will send out a new SIM card  with your number on it.
 Is this an upgrade or is it a phone that you’ve already got or plan on purchasing ? ( not a upgrade )
Been given a newish phone better than existing so just need to replace SIM with new size tariff was orange though
Re: When changing phones w/o tariff changesffs
No you can use whatever phone you want. If you need a new sim then you can either call CS and order one or go here.
Thanks,
Hi @Chaltonadvisor,
Welcome to the EE Community.
If you need a different sized SIM for your Orange plan, please get in touch with customer services and they'll be happy to help.
